Briel - Multi-Pro Series
Hallo,
Ik ga deze week een Briel Multi-Pro Series ophalen(€ 85,00). Gevonden op Marktplaats.
Het lijkt me een geweldig apparaat gezien de informatie op het web.
Heeft iemand ervaring met dit apparaat?
Constant 18 Bar pump pressure produces a savory espresso with perfect crema every time - guaranteed! (This is substantially above the minimum requirement of 9 Bars necessary for an authentic espresso.)
ESE adapted for use with ground coffee or single coffee servings (pods).
Turbo Jet Frother combined with thermo block technology, a Briel exclusive, instantly produces plentiful dry steam for a thick milky froth for cappuccinos or lattes.
CremaMaster™ filters for ground coffee or pods produce rich genuine crema every time, and AquaStop™ No-Drip System prevents dripping and need to "bleed" machine of remnant water.
Two thermostats regulate the coffee cycle and steaming process for the pump, with a third "safety" thermostat located on the pump in the event of abnormal or continuous use.
"OK" light signhals when machine is ready for brewing or frothing.
Push button switches.
Removable 2 liter water reservoir that fills from the back.
Water level visible from the front with water filter on intake.
Removable overflow tray for easy cleanup.
2 brass filter holders - one for ground coffee and the other for coffee pods.
Built-in coffee tamper and measuring spoon included.
UL Approved.
Power: 120 volts; 1600 watts
Dimensions: 13L” x 12.5W” x 15H”
Weight: 20 lbs.
Color: Steel/Silver
One year warranty (parts & labor)
Made in Portugal
Re: Briel - Multi-Pro Series
Athenatius schreef:Hallo,
Geen ervaring, maar de tekst is iig een verkooppraatje.
UL Approved.
Weight: 20 lbs.
Color: Steel/Silver
Made in Portugal
18bar druk? Als dat echt het geval is, wordt de koffie zo hard samengedrukt dat er geen water meer doorheen kan. 9bar druk is zeker niet het minimum, maar een gemiddelde waarbij espresso vaak goed is. Met hevelmachines kan je met 6 bar nog een prima espresso maken, en 10-11bar gaat ook nog wel, maar 18 bar is gewoon véél te veel. En waarschijnlijk nog onzin ook (max. druk geleverd door vibratiepompjes is vaak 18bar; die zitten ook in de grotere thuismachines).
"Turbo Jet Frother combined with thermo block technology, a Briel exclusive, instantly produces plentiful dry steam for a thick milky froth for cappuccinos or lattes."
Thermoblockjes zijn natuurlijk niet exclusief door Briel gebruikt, die zijn zeer gebruikelijk. En al die andere machines kunnen ook gewoon stomen. Instantly? Nee hoor, zal toch echt even moeten opwarmen.
"CremaMaster™ filters for ground coffee or pods produce rich genuine crema every time"
echte, dus 'genuine', wordt juist niet geproduceerd door filters, maar komt gewoon uit de koffie zelf.
"and AquaStop™ No-Drip System prevents dripping and need to "bleed" machine of remnant water."
Eh?
Ja, het klinkt wel als een verkooppraatje. Toch heb ik al op verschillende sites gelezen dat het om 18 bar gaat.
Volgens ConsumerGuide products:
The Briel MultiPro ES200APG-TB is a beautiful and highly efficient pump machine that produces cup after cup of intense-flavored espresso coffee with virtually no waiting. This unit is made from heavy-duty stainless steel that has been polished to a gleaming mirror finish. It stands just under 13 inches tall, 12.2 inches wide, and 15 inches deep -- although you will need a little extra room behind the unit to accommodate the power cord.
Standard equipment for the MultiPro includes the base unit, a removable 2-liter clear plastic water reservoir, two brass filter holders with sieves, built-in coffee tamper and measuring spoon.
The MultiPro's most impressive feature is the thermo block system, which uses two separate thermostats to regulate the espresso brewing and steaming/frothing processes. On units with a single thermostat, there is a wait time while the unit heats up to produce steam or cools down again to brew espresso. With the thermo block, you can literally switch back and forth between these functions with no waiting. A third safety thermostat also regulates the pump for continuous use.
One other feature on this unit deserves special mention. The patented Auto-Espresso-Flow function has an electronic timer that lets you simply turn and release the brew dial and watch as the espresso is automatically dispensed. A second dial lets you set the quantity, so whether you prefer a tall shot or short shot of espresso, the MultiPro can be set to deliver based on your specified preferences -- anywhere from just a few ounces to a full cup and a half.
The pump pressure delivered by the MultiPro is amazing. The unit delivers 18 BAR of pressure (substantially higher than the 9 BAR necessary for an authentic espresso). A manometer gauge on the front of the unit shows the amount of counter pressure made during operation. Additional features include a handy water-level indicator on the front and coffee tamper.
The unit's three dial controls turn the unit on, operate the brew and steam functions and also let you preset the brew quantity. As previously mentioned, the thermo block system is so efficient there is literally no wait time. The unit is ready for brewing in about 15 seconds after turning the power control to the "on" position. Separate power and ready lights let you know the unit is preheated and ready to brew. You can also dispense hot water for tea through the steam nozzle by using the brewing and steam switches simultaneously.
The patented Cremaster filters produce an excellent cup(s) of espresso using either ground espresso coffee or pre-packed espresso pods. We noticed an ample amount of the thick foamy layer of crema -- the hallmark of great espresso.
Pros: 18 BAR pump, thermo block system, quick and efficient operation, Auto-Espresso-Flow function
Cons: Pricey
Athenatius schreef:Tja, een ander type + het eerste kopje espresso...moet het misschien nog leren?
Vergelijken met een Senseo is wat overdreven lijkt me.
Ik kan me nu eenmaal geen duur apparaat veroorloven.
Wil gewoon weten of er iemand ervaring mee heeft.
Duur hoeft niet.Misschien beter even op dit forum orienteren en over een paar weken een beargumenteerde aankoop doen.Als ik jou was zou ik de koop terugdraaien en eerst wat onderzoek doen.Misschien is de machine in staat tot fatsoenlijke koffie maar misschien ook niet.
