The "Pull" Lever Espresso Machine
Best wel "Tussen Kunst & Kitsch" :P
http://dailycoffeenews.com/2016/09/07/b ... -machines/" onclick="window.open(this.href);return false;
Beauty, Consistency, Longevity: Pull Luxury Espresso Builds ‘100-Year Machines’
Howard Bryman | September 7, 2016
No one is better versed in the inevitable faltering of the electronic components in today’s commercial espresso machines than the people that sell and repair such machines. Of course, the manufacturers stand by their products and many will make excellent espresso for as long as they last, but no electronic device lasts forever.
A new maker of manual spring-lever espresso machines called Pull Luxury Espresso Machines has emerged to take a stand against this phenomenon, making what they call “100-year machines.”
Pull machines borrow time-tested mechanical principles from classic hand-pulled spring-lever machine designs and update them with materials and workmanship they claim is superior to those of eras gone by as well as to those of today’s typical mass-manufacturing sensibility.
“All electronic machines are trying to do, all this technology, what we’re trying to do is mimic or copy what the hand pull machines do, and do very well,” said Todd Millar, cofounder of Pull Luxury Espresso Machines. “I can make this blanket statement because I’ve seen them all. There’s not many machines I haven’t seen or been in contact with.”
Millar got his start building espresso carts in Seattle in 1989. With a four-person crew and a small woodworking shop on 1st Ave S, they eventually started also importing the machines to pair with their carts. They also found a lot of clients that wanted a setup with the least electrical demand possible.
“The solution was hand-pull espresso machines that run on propane,” said Millar, who started importing, selling and servicing lever machines as well. “That’s when I fell in love with hand-pulled espresso machines.”
Ten years later, Mary and Todd Millar moved on from the cart-building business and relocated to Portland, Ore., where they focused more on the import, service and repair of electronic machines. As years went by, Millar would sometimes wonder if his recollection of the great coffee from lever machines was just a romanticized memory until a client would request a manual machine and he’d import one and test it.
“It always proved to be true. I was always like, ‘wow, the coffee is better,'” Millar recalled. “It’s not just in my head.”
Coming up on 30 years in the industry, Millar said he has clients that he’s sold three or four machines to and is all too well acquainted with the cycle.
“It’s terribly unexciting to keep selling someone another electronic machine because their last machine becomes cost-prohibitive to maintain,” Millar said. “The computers, the electronics, the pumps, solenoids, flow meters — all these things, they have a life span. They can only produce so many cycles. They can only produce so many cups of coffee before they’ll need service that becomes cost prohibitive.”
Yet the people he had sold hand-pull machines to over the years still had the same ones, and they still work perfectly with just a replacement gasket or switch here and there. “They’re very simple,” Millar said. “That always inspired me as well.”
Pull Luxury Espresso machines are built by the company with goals of providing ideal preinfusion, temperature stability, shot consistency and easy maintenance, but they’re also built to be both beautiful and as long-lasting as possible. Each hand-made machine is encased in walnut with hand-cut dovetails, with walnut portafilter handles and hand-stitched Italian leather-wrapped lever handles.
An Edison light bulb illuminates behind the rear Pull logo plate. Efficient heat transfer occurs by having the group bolted directly onto the boiler, while thermal stability is maximized by the sheer mass of the group — a 22-pound hunk of solid brass, chromed on the outside and with a stainless steel interior sleeve.
The boilers are made out of 99 percent pure copper and are finished with an oven-baked clear gloss powder coat. What few wires are required inside are shielded and connected with all high-temperature-rated components, and the frame is made of 1/8-inch-thick iron, triple-layered in oven-baked, powder-coat finish as well.
Materials and treatments such as these, and the attention to detail with which Pull assembles each machine are what set Pulls above even the other lever machines currently in production, according to Millar.
“What’s very disappointing to me is that manufacturers in Italy still build hand-pull machines, but they now build them with the mass-production thought process,” said Millar. “We felt like it needed to be built by hand and with great care.”
Millar contends that what grants a lever machine greater power of excellent espresso is essentially its gentle, even and effective preinfusion, the process for which in an electronic machine grows so convoluted that the cards are stacked against it happening perfectly every time, if at all.
A switch or touchpad turns on the motor, the motor moves the pump, a flow meter measures an exact amount of water and a solenoid opens to let it through; in most cases the pressure goes disruptively from zero to 140 PSI almost immediately, while in some cases there are systems for managing and “profiling” the pressure, yet even the latter are only striving to achieve what lever machines are engineered to achieve with consistency and precision, in Millar’s view, without any complex electronics.
Slower, gentler preinfusion allows for a more thorough extraction, so effectively according to Millar that one could theoretically pull an equivalent or superior shot even with a lower dose, while its prevention of channeling — the enemy of shot consistency — verges on the supernatural.
“This is mind-blowing, but I’ve gone as long as a full month without changing the grind,” said Millar, who in his many years of training electronic machine users has always issued caveats that the grind typically needs to be adjusted three or four times a day in a commercial environment, resulting in a necessary though regrettable waste of coffee.
“I’ve never had any machine that I could go that long without changing the grind in my showroom,” he said. “It goes against everything that we know about espresso.”
For explorers in today’s era of espresso experimentation, a variable rate of preinfusion has for a while been a significant advantage among newer semi-automatic machines, although an advancement by Italian lever group designers and adopted by Pull through the group head it sources provides this variability as well. The group of a Pull machine features an adjustable valve that allows users to calibrate and dial in their preinfusion pressure based on such factors as altitude, desired boiler pressure or personal preference.
The aesthetic experience of baristas operating a hand-pulled machine is meanwhile another element of heritage that Millar hopes to bring back to the commercial sphere with Pull machines.
“A lot of things in the old days had two purposes, like a Hi-Fi console was a piece of furniture, and it was also an apparatus for listening to music,” Millar said. “Everything’s getting so impersonal, things are getting smaller, and I believe that we’ve lost something by not having an aesthetic. An espresso machine should be a piece of art in your café, as well.”
The old world sensibility also guides the Millars in their roasting company, Millars Organic Wood Roasted Coffee. With four buildings spread out over seven acres in Yacolt, Wash., near Mount St. Helens, the Millars run three operations: Pull Luxury Espresso Machines; their older and ongoing machine import, sales and service business called The Original Espresso Machine Company; and a roastery centered on an antique 15-kilo Turkish roaster they modified to run on naturally fallen cherry and maple wood from around their property.
The wood smoke and heat runs directly over the beans, affecting its flavor, and they were also an early adopter of the barrel-aging technique, conditioning green beans in Kentucky bourbon barrels.
“The coffee business is a very small part of our business. We do it because we love coffee,” said Millar. “We want to stay small and be true to the craft. Wood roasting is hard to scale anyway; it’s not practical on a large scale.”
Similarly, Pull Luxury Espresso Machines are also not intended to take over the world. “The goal of Pull is to be true to the making of great espresso,” said Millar. “It’s not to be the biggest. It’s just to be the best, and to not compromise.”
Pull Luxury Espresso Machines are currently in their first run of production. The company sells a single-group machine for $8,500, or a two-group machine for $10,500, both of which prices include professional installation, training and support.
https://www.pullespressomachines.com/home.html" onclick="window.open(this.href);return false;
The Coffee Cantata - J.S.Bach
Re: The "Pull" Lever Espresso Machine
Zelfde zetgroep als Londinium / Profitec en andere, met wat eigen aanpassingen. Verder ook vrijwel gelijke opzet, boiler, pressostat, control box, de gewone simpele basis-elektronica die in bijna al dergelijke machines zit. Een dipper design zoals de Profitec, niet duidelijk of er een of twee veren in zijn besteld.
Het unieke zit 'm in de "espresso voor kampers" look en in het prijskaartje ;-)
En ook weer afzetten tegen andere producenten.
Wij zijn beter en de anderen( vooral de Italianen :mrgreen: :mrgreen: :mrgreen: doen alles verkeerd) en oh oh wat heb ik lang nodig gehad om de juiste maalgraad te vinden.Zo goed is die.... :roll: :?: :roll:
Gisteren weer eens espresso uit een oude 820 gedronken.
Wel met goede verse koffie.
Was gewoon lekker.Niet beter of slechter dan uit mijn pompei.
cremalover schreef:Wel met goede verse koffie.
Als je met goeie bonen begint kan er verder niet heel veel mis gaan. Van goed naar fantastisch is een lange kostbare weg die niet voor iedereen de moeite waard is.
Voor mij inderdaad zo.Kan ook zijn dat mijn smaakvermogen vermindert.Dat schijnt voor te komen bij het ouder worden.
Ik kan me niet aan de indruk onttrekken dat ik dat Frame al eerder gezien heb bij een andere machine, het komt me zo bekend voor ik ben maar aan het malen (geen koffie) waarzo dat was/is.
Het doet me ook met een vleugje van (H)erkenning denken aan het werk van Dmitriy Tikhonenko, deze heeft een uitgebreid repertoire van allerhande "Steampunk" machines en aankleding van huizen en gebouwen
https://www.facebook.com/coffee.expert/ ... 03/?type=3
https://www.google.nl/search?q=steampun ... 80&bih=663
http://www.homecrux.com/2014/08/01/1882 ... stech.html
http://steampunkgirls.tumblr.com/ 8-)
Dat lampje achterin? wordt het dan toch een tafellamp?
Laatst gewijzigd door @3aan op ma 12 sep 2016, 11:45, 1 keer totaal gewijzigd.
cremalover schreef:Dat lampje is voor inspectie of stellen van de presso.
Zit zelf altijd met mijn zaklamp te klooien.
Dat is wel handig bedacht.
Wel handig dat het lampje naar onderen schijnt en ook lekker laag hangt,
de afstelling van de Pressostaat zit vlak onder de bovenkant van de machine,
kan nu wel zien waar dat Donker en Glimmend vandaan komt. - - :mrgreen:
Ik kan me ook geen voorstelling maken waar dit stekkerblok voor dient,
nog meer losse en corroderende contacten?
