Wilfa grinder. 54mm flat burrs, bluetooth scale with 0,1 g increments, app with grind setting recommendations by your Tim Wendelboe. Works ok for espresso even with VST filters and great for all other brew methods. Made very tasty brews around 21% extraction with a filter brewer and various coffees and roasts. It grinds slow to not over heat the coffee and stops automatically when there are no more beans in the hopper. No timer. Just the on/off button is all you need. Anti static grounds container.
